Avic D3 - Backgrounds
Sponsor
Sponsor
Postby rwwilkins on Fri Jun 01, 2007 6:31 pm
The sticky tutorial above says its for d1 and d2's only.
Is there something for the d3's?
Getting my d3 installed tomorrow.
Thanks,
Rich
rwwilkins
Postby Robb on Sat Jun 02, 2007 5:30 pm
i was wondering the same thing. i've been itchin' to change my d3's bg :)
Robb
Postby bobmun on Sat Jun 02, 2007 5:31 pm
it is in the owners manual.
User avatar
bobmun
Postby Ralphmac on Sun Jun 10, 2007 9:13 pm
Create a folder on your desktop/laptop that is named pictures. Drag the jpg. images into the folder. Once you have done this upload the folder on an ISO image maker program like ULTRAISO. Also make sure that you have over 100MB's. So you will need to upload some dummy data do not put this in the folder. I used the Pamela Anderson/Tommy Lee video LOL. I then used Alcohol 120% and burned the image to the CD. Went out to the Avic D3 and loaded the images up. Any questions please respond.
Ralphmac
Postby PhatheadWRX on Mon Jun 11, 2007 8:39 pm
Here is a quick Q:
Can I copy my Nav disk, add a Pictures folder with jpgs, burn and use that? Is there anything special about the nav disk or can I just burn it as a regular data DVD-DL?
PhatheadWRX
Postby Ralphmac on Mon Jun 11, 2007 10:32 pm
That is a good question. Give it a shot and see what happens. I'm curious myself.
Ralphmac
Postby trikkky on Mon Jun 11, 2007 10:56 pm
if you read or even went to your d3 and went to system backgrounds and tried to "import" it clearly says burn images on a cd-r and make sure on the disc there is a folder named PICTURES and in that folders put your jpegs in there.
trikkky
Postby PhatheadWRX on Tue Jun 12, 2007 3:09 am
just tried to copy/paste the contents of the disk then add the Pictures folder then burn UDF mode in Nero... no dice.
It would not even let me set a picture off the DVD. It said no such folder. I wonder if a picture CD must be on a CD or single layer?
I'm now ripping the disk to an ISO and going to try and add the pictures folder to the ISO then burn
edit: could not get the ISO open in winISO so I just quit and burnt a CD-R with the pictures folder
PhatheadWRX
Postby trikkky on Tue Jun 12, 2007 4:32 am
it shouldnt matter what format it is . EVEN tho i used a cd-r .. make sure on the cd-r there is a folder named PICTURES in caps.. and in that folder put your jpegs.. to be safe forget the dual layers and dvds just burn it on a regular cd-r
trikkky
Postby gregbj33 on Thu Jun 14, 2007 5:03 am
having trouble. i mad a PICTURES file and added some backgrounds then also added a file that put the total size at somewhere around 22 mb. burnded them to cd-r and it will not work. manual says nothing about burning them as an iso image or anything like that. anyone have ideas.
2008 Mercury Sable Premier
Avic-F900bt
gregbj33
Postby trikkky on Thu Jun 14, 2007 5:20 am
no need for iso.. just burn the jpegs in the folder PICTURES.. simple as that then go to backgrounds and click import from cd
trikkky
Postby madzozs on Sat Jun 16, 2007 7:30 pm
trikkky wrote:no need for iso.. just burn the jpegs in the folder PICTURES.. simple as that then go to backgrounds and click import from cd
I got mine installed yesterday and tried to do this using the Windows burning utility(Vista), and it didn't work. It kept saying there is no /PICTURES/ folder found.
I'm assuming it is just an issue with Vista taking my favorite CD/Data burning program(built-in XP one) and ruining it.
Any other suggestions?
madzozs
Postby trikkky on Sun Jun 17, 2007 7:09 am
don't really know much about vista.
trikkky
Postby VBLUE42 on Sun Jun 17, 2007 8:15 am
I use a mac and all I did was create the PICTURES folder with jpegs in it on the desktop. Then create a new disk and drag the folder into my app and it worked just fine. I burned it as a windows/mac cd with no problem. No need to make the contents of the folder any large size either. Mines only 1.5 megs. You need to have your PICTURES folder with jpegs, open your app and create a new cd, drag the PICTURES folder into the newly created cd, and burn it. Its really that simple.
User avatar
VBLUE42
2000 Club
Postby jkim1978 on Thu Jun 21, 2007 2:47 am
after burning the cd and setting the picture on the option, when you take out the cd... and stick in the navigation cd.... the images disappear? or are images stored as a memory or something????
jkim1978
Next
Return to Creating Custom Backgrounds
Who is online
Users browsing this forum: No registered users and 0 guests
