Indeed Toxarch... Very helpful.... I can't thank you enough...
I finished it up with the SWI-X for steering wheel controls, which turned out better than I thought it would... and wrapped the entire thing up with a JL Stealth Box over the weekend... which did not fit near as well as I was hoping, as the mounting brackets wouldn't line up right.. But I managed to get them bent into shape...
I hated the SWI-PS in my Chevy truck as it would only work when it felt like it, and the functions were limited... SO this time I used the PAC SWI-X... The SWI-X can learn alot more fuctions than most of the other interfaces, including Voice command...cancel/back...as well as answer and hang up...
The only problem I had, was that the stock voice command button had an issue programming against the volume down... I guess there tied into each other somehow... But it turned out better, as the SR1 remote's VC/back and answer and hang up buttons switch roles dependant on what's going on(i.e when you get a phone call or during a call)... sooo I just progrmmed the stock answer/hang up buttons to VC and back.... as you might can make out from the pic, it has a secondary role when either in a call or when you're receiving a call.. Worked out perfect...
Cruddy Iphone pics...
I was going to extend the IR up to the overhead, but found that it worked just fine at the center console without needing to splice and extend the emiter(even in diect sunlight)
Actual IR emitter
Now I just have the Ford to do... yea...
