Owners: Post your issues here.
This topic contains all the old discussions prior to the launch of the F Series.
Sponsor
Sponsor
Postby JasonH on Wed Jun 11, 2008 12:51 am
Hey Guys,
For those of you that own F Series units and are having repetitive issues, please post the following so I can send an organized list to Pioneer to see if they can help us out.
Model:
Devices Connected (XM, iPod, etc) :
AV Source (if playing) during issue:
Action that caused the issue (pressed button, search, etc):
Was GPS routing? (yes/no)
Was BlueTooth active? If yes, what device?
Anything else you would like to add:
Thanks,
Jason
User avatar
JasonH
Site Admin
Postby rdkl on Wed Jun 11, 2008 5:05 pm
If you answer a call on the bluetooth while on xm or ipod it will stich over to the map.
User avatar
rdkl
Postby rdkl on Wed Jun 11, 2008 5:07 pm
Using a playlist with an Ipod doesn't work right. All of the tracks will be in alphabetical order instead of the playlist order.
This happens with the original Ipod nano (and others from what I read) but does not happen with the iPhone.
User avatar
rdkl
Postby coasterlvr on Wed Jun 11, 2008 8:37 pm
Model: F90BT
Devices Connected (XM, iPod, etc) : XM, Sirius, Ipod
AV Source (if playing) during issue: any
one of my issues is with the distorted voice commands and beep. i'm not sure if this is an issue without amplifiers, but it's pretty bad imo with them. normal audio is great, but any push of a button or voice command is distorted no matter what volume i set it at.
yes, my screen changes to map when using the phone too.
the ipod startup is horribly long.
i need to play with mic placement some. i can't seem to get much voice recognition to work.
i'm going to start driving the car more so i'll report more soon.
jtaudioacc.com
Pioneer CDX-P680 6 disc changer for sale, mint condition.
coasterlvr
Postby rdkl on Wed Jun 11, 2008 8:53 pm
Same noise without amps. I only have an amp on my sub and I hear the same thing.
User avatar
rdkl
Postby openhelix on Wed Jun 11, 2008 10:04 pm
Could it be a ground loop in your install?
openhelix
Postby rdkl on Wed Jun 11, 2008 10:07 pm
The sound on mine only affects the voice and the beep. Music is fine and there is no noise the rest of the time.
Also it doesn't sound like any ground loop I have heard before.
User avatar
rdkl
Postby mikeinnj on Wed Jun 11, 2008 10:49 pm
I haven't seen much of this yet, but I could not get text to speech to work on mine for pronouncing street names.
User avatar
mikeinnj
Postby rdkl on Wed Jun 11, 2008 10:52 pm
No street names here.
Also, when you arrive at the destination it doesn't say which side of the road its on. This can be pretty annoying.
User avatar
rdkl
Postby rdkl on Thu Jun 12, 2008 3:24 am
Lost a bunch of our xm stations tonight. Had to shut the radio off and back on to get them back.
Also, clock is now wrong on this unit and changing it to auto or manual doesnt fix it. Was 2 hrs and some minutes off, after cycling between the 2 settings it is now only 10 mins off but can't get it to correct. Going to try hitting the reset button on here tomorrow.
Playing music from usb thumb drive tonight it kept stopping like a scratched cd.
User avatar
rdkl
Postby capper on Thu Jun 12, 2008 3:40 am
rdkl, maybe you should just post what works. :)
capper
rdkl wrote:No street names here.
This does have text to speech doesn't it?
capper
Postby rdkl on Thu Jun 12, 2008 4:46 am
I do a lot of as work so I tend to look for problems. Or maybe they just find me;)
I haven't found a feedback alias or anything so I hope someone over there sees this thread so we can get some fixes!
Functionally this unit is usable right now. It will be fabulous with some updates :)
User avatar
rdkl
Postby rdkl on Thu Jun 12, 2008 2:05 pm
Found another one :)
I got mine to do txt to speech as far as naming the next turn, etc.
If you go to settings and languages and change the voice to Samantha it will call out the names of roads for you. Unfortunately it says 1,2 instead of 1.2 but at least it tells me what road I am going to turn on :)
Also a couple of features I'd like to see added to the list sent to Pioneer:
1. the ability to turn off muting of music while nav is speaking like the z2 had.
2. button to turn off voice prompts while navigating
User avatar
rdkl
Postby dwhitley0381 on Thu Jun 12, 2008 2:25 pm
my unit is working ok... I expected it to be a little more hmmm whats the word.... well like a factory radio nav system. After market should be the best... I have to ask does Pioneer not have a R&D department to test these units? I mean of all the problems you are having they should have seen these already and fixed them. Contact your attorney generals office and file a complaint....then they will release better quality products the first time. I have since put my Z1 upgraded to a Z3 back in...
dwhitley0381
Next
Return to Pre-Release Archive
Who is online
Users browsing this forum: No registered users and 0 guests
