How To: Complete TA 2009.6 Map Upgrade Guide - Please Sticky
Please note: Hacks and Mods are unofficial and are not covered under warranty by Pioneer.
Moderator: skicrave
Sponsor
Sponsor
Postby LTdan on Wed Nov 25, 2009 4:17 pm
In order to avoid confusion and repeat threads, I have taken the liberty of finally posting a, once and for all, all questions answered HOW TO on the 2009.6 map upgrade with working links.
1. Download the 16 rar files located on the top of this website (yes... you need to dl all 16)
http://www.filecrop.com/search.php?w=83_Cont_USA_2009.06_TA.part&pos=1&opt_t=1&opt_d=0&order=score&mod=dec&size_i=0&size_f=1048576&c=20
2. Once you have finished downloading all of them unzip the first one (it will automatically extract all 16) and enter the password: "ppcwarez.org" in all caps no quotations
3. Next you need to download the cracked EZrider which can be found on this link:
http://rapidshare.de/files/48133221/ezrider.rar.html
4. Now download the Generic License Code from this link:
http://www.gpssoftware.us/avic/newez4avic.zip
*Note: the above link contains a EZrider file that DOES NOT WORK. you can discard it after you unzip.
5. Put all the extracted files onto an SD card and head to your car.
6. Backup your map files
7. Delete the contents of the Map, Dem, Building, POI, and Speedcam folders from your nav unit and CUT and PASTE the new files into their respective folders
*Note: You may have to delete a map in order for it to fit (the map files are too big for the nav). I deleted Mexico. Also realize that the 2009.6 files do not include the basemap.fbl file. You need to keep this file!
8. Replace the stock EZrider.exe with your new hacked one.
9. Copy and Paste your generic license into the license folder (do not delete any others!)
10. Reboot and enjoy running on your new maps!
Troubleshooting:
Situation: Upon Startup the "System Startup in progress please wait..." message displays and stays on.
Solution: You copy and pasted over the wrong EZrider. Use the one from the link in step 3
Situtation: Upon Startup the system keeps self rebooting
Solution: You may have some corrupted files from step 1. Try downloading them all again
LTdan
Re: How To: Complete TA 2009.6 Map Upgrade Guide - Please Sticky
Postby laci102 on Wed Nov 25, 2009 9:04 pm
I would like to ask for assistance:
I've got Pioneer AVIC f900bt types of apparatus (Hungary).
The maps I would like to replace it, just the ezridert yet to be replaced or else I do?
Thank you! :)
laci102
Postby diaftia on Thu Nov 26, 2009 5:27 am
Thanks for the writeup LTDan. You might want to edit this step:
7. Delete the Map, Dem, Building, POI, and Speedcam folders from your nav unit and CUT and PASTE the new files into that folder
to read:
I didnt download all the files but the way the directions read it seems as though you tell them to delete the folders but don't mention if the new files are already in the correct folders or not. I have found that some people like the directions very literal.
Join my new AVIC facebook group to show you are a fan of the AVIC!
http://www.facebook.com/group.php?gid=42760514227
User avatar
diaftia
Postby 69sixpackbee on Thu Dec 03, 2009 7:09 pm
Thanx!
69sixpackbee
Postby 69sixpackbee on Thu Dec 03, 2009 7:11 pm
I noticed there are no Hawaii Map files but a POI file. Is this correct?
Thanx,
Bud
69sixpackbee
Postby laci102 on Fri Dec 04, 2009 7:44 am
Please help: I upgraded to the 3.0 version of the Pioneer unit, I did it!
I have a problem: I replace the maps legfrissebbekre the machine does not recognize what can be done to recognize?
Thank you in advance for your help!
laci102
Postby LTdan on Sat Dec 05, 2009 6:38 am
69sixpackbee wrote:I noticed there are no Hawaii Map files but a POI file. Is this correct?
Thanx,
Bud
Never noticed that... I'm sure you could find a TA Hawaii map online if you really wanted. I'm probably gonna have to set up more links as to where to find all the maps when I get the chance. If you find it, post the link and I'll edit it to the first post!
LTdan
Postby 69sixpackbee on Sat Dec 05, 2009 6:54 am
I found it. I had to re-download the files. It got corrupted somewhere. All is good now!
Thanx,
Bud
69sixpackbee
Postby Bman69 on Sat Dec 05, 2009 9:01 am
I am not a fan of passwording rars so I downloaded all these and rared them up without the password for anyone who has usenet
nzb file is in the attached rar
83_Cont_USA_2009.06_TA-nzb.rar
Extract the rar to get the .nzb file
(8.54 KiB) Downloaded 603 times
Bman69
Postby speed on Sun Dec 06, 2009 3:43 pm
Do you need testmode and windows on the sd card in order to transfer the maps?
speed
Postby speed on Sun Dec 06, 2009 5:50 pm
speed wrote:Do you need testmode and windows on the sd card in order to transfer the maps?
Nevermind, I figured it out.
Awesome write up OP. Everything went smooth.
speed
Postby moegenki on Mon Dec 07, 2009 6:48 am
Scratch that found the answer
moegenki
Postby ghale on Wed Dec 09, 2009 10:06 pm
I just want to clarify the requirements for these maps.
I currently have version 3.1 running on my F90bt. Will this map be compatible?
Some files appear different that what I currently have. They are:
1) Currently I have several different DEM files: Africa, Canada, Eurasia, North_America, Oceania, and South_America. Do I really need to remove all of these when the new map content only has NorthAmerica_low_2008_03_25?
2) My current speedcam file has a .spud extension whereas this map has .stxt extension. What is the difference... I'm assuming they will continue to work.
Thanks.
ghale
Postby deuceduzit on Fri Dec 11, 2009 6:47 am
So I did as instructed & my GPS wont get a connection.... Very weird.... When I press the MAP button it just tries to continuosly search for a GPS signal.... I'm running 3.01
Any help would greatly be appreciated.... Thanks
deuceduzit
Postby Ayhan312 on Sat Dec 12, 2009 8:23 pm
I got a brand new F500BT and did the following:
1. Updated firmware to 2.0006 (from Pioneer's website), didn't update TTS
2. Download the 16 part new maps, EZRIDER and generic license file and opened them in my computer
3. The size of all files is looks ok
4. I copied all files as per instructions to my device.
5. Turned off the system.
6. Removed my SD Card
7. Turned on the device
Here system started rebooting itself (in a loop, didn't go to main screen). I de-compressed the files and did the whole process again, result is same thing.
I copied the original files back to my device, now everything is ok (with old maps).
I appreciate if somebody can advice me how can I get around this issue and install the new maps?
Ayhan312
Next
Return to Hacks/Mods
Who is online
Users browsing this forum: Ask Jeeves [Bot], MSN [Bot], ndy4eva and 4 guests
